Knowledge Base Article
RapidIO IP Core User Guide Lists Wrong TOP_LEVEL_NAME for ModelSim Simulation of Arria 10 IP Core Variations
Description
The name of the RapidIO IP core top-level file for simulation in the ModelSim simulator changed in the IP core v14.1 and later, for simulation of IP core variations that target an Arria 10 device. The user guide lists the filename <your_ip>_altera_rapidio_140.tb_rio. However, the correct filename, starting in IP core version 14.1, is <your_ip>_altera_rapidio_<version>.tb. The RapidIO MegaCore Function User Guide is not updated with this change.
For a similar issue with non-Arria 10 variations, refer to RapidIO Core User Guide Lists Wrong TOP_LEVEL_NAME for ModelSim Simulation of Non-Arria 10 IP Core Variations.
Resolution
Ensure that you simulate your Arria 10 RapidIO IP core in the ModelSim simulator with TOP_LEVEL_NAME set to <your_ip>_altera_rapidio_<version>.tb. For Arria 10 variations of the IP core, replace the simulation instruction
set TOP_LEVEL_NAME <your_ip>_altera_rapidio_140.tb_rio
with the new simulation instruction
set TOP_LEVEL_NAME <your_ip>_altera_rapidio_<version>.tb
This issue will be fixed in a future version of the RapidIO MegaCore Function User Guide.
Updated 1 month ago
Version 2.0
