Knowledge Base Article
RapidIO IP Core User Guide Lists Wrong TOP_LEVEL_NAME for ModelSim Simulation of Non-Arria 10 IP Core Variations
Description
The name of the RapidIO IP core top-level file for simulation in the ModelSim simulator changed in the IP core v14.1 and later, for simulation of IP core variations that target a non-Arria 10 device. The user guide lists the filename tb. However, the correct filename, starting in IP core version 14.1, is rapidio_0.tb. The RapidIO MegaCore Function User Guide is not updated with this change.
For a similar issue with Arria 10 variations, refer to RapidIO Core User Guide Lists Wrong TOP_LEVEL_NAME for ModelSim Simulation of Arria 10 IP Core Variations.
For a related issue for non-Arria 10 variations, refer to RapidIO IP Core User Guide Lists Outdated Instructions for Simulation of Non-Arria 10 IP Core Variations.
Resolution
Ensure that you simulate your non-Arria 10 RapidIO IP core in the ModelSim simulator with TOP_LEVEL_NAME set to rapidio_0.tb. For non-Arria 10 variations of the IP core, replace the simulation instruction
set TOP_LEVEL_NAME tb
with the new simulation instruction
set TOP_LEVEL_NAME rapidio_0.tb
This issue will be fixed in a future version of the RapidIO MegaCore Function User Guide.
Updated 3 months ago
Version 3.0
