Knowledge Base Article
RapidIO IP Core Might Lose TX Buffers During Resynchronization of ackID Value
Description
If you resynchronize the ackID value for your RapidIO IP core instance, the IP core should reset the expected ackID value in the Port 0 Local AckID CSR at offset 0x148. The change tells the IP core the next packet to acknowledge.
However, the RapidIO IP core does not update this information correctly. Therefore, the IP core does not identify buffers to be freed when packets are acknowledged, and the IP core might eventually run out of buffers to send packets.
Resolution
This issue has no workaround.
This issue is fixed in version 11.1 of the RapidIO MegaCore function.
Updated 3 months ago
