Knowledge Base Article
RapidIO IP Core Might Incorrectly Flag CRC Error
Description
If a RapidIO IP core receives the following sequence of symbols on the RapidIO link, followed by data, the IP core might incorrectly flag a CRC error.
start-of-packetcontrol symbol- NOP (Ignore) symbol
The probability of the IP core flagging a CRC error following
this sequence is 50%, because this error occurs only when the IP
core maps the start-of-packet control symbol to the
upper 64 bits of the 128-bit internal data bus.
Resolution
This issue has no workaround.
This issue is fixed in version 14.1 of the RapidIO IP core.
Updated 2 months ago
