Knowledge Base Article
RapidIO IP Core Has Wrong Default TX VOD Setting in Arria V and Cyclone V Devices
Description
The RapidIO IP core does not set the transceiver TX VOD value correctly in Arria V (GX, GT, SX, and ST) and Cyclone V devices. The default value violates the RapidIO specification.
This issue affects all RapidIO IP core variations that target a Cyclone V device or an Arria V device other than an Arria V GZ device.
Resolution
To fix this issue, add the following line to the Quartus II Settings File (.qsf) for your Quartus II project:
set_instance_assignment -name XCVR_TX_VOD 50 -to <td>
where <td> is the transmitter serial output pin to your RapidIO link.
This assignment sets the TX VOD to the value of 500 mV.
This issue will be fixed in a future version of the RapidIO MegaCore function.
Updated 2 months ago
Version 2.0
