Knowledge Base Article
RapidIO II Simulation testbench failure when parameter "Enable Transceiver control and status register" is enabled.
Description
For Arria® 10 and Stratix® 10 families. When RapidIO II IP Core is generated with the optional parameter "Enable transceiver control and status register" enabled, the provided simulation testbench will fail. The failing behavior is that the transceiver does not exit from reset, and rx_is_lockedtodata does not assert.
Resolution
Advice is to run the simulation without enabling the parameter "Enable transceiver control and status register" if affected.
This problem has been fixed starting in Quartus® Prime software version 17.0.
Updated 2 months ago
