Knowledge Base Article
RapidIO II MegaCore Function User Guide Does Not Explain sys_clk and Transceiver Reference Clock Constraints
Description
The two RapidIO II IP core input clocks, sys_clk and tx_pll_refclk,
must derive from a common clock source. If your design does not
enforce this constraint, the IP core may experience FIFO underflow
or overflow. However, the RapidIO II MegaCore Function User Guide
does not document this constraint.
Resolution
To avoid this issue, ensure that your Avalon system clock, sys_clk,
and TX PLL reference clock, tx_pll_refclk, derive from
This issue is fixed in version 14.0 of the RapidIO II MegaCore Function User Guide.
Updated 2 months ago
