Knowledge Base Article
RapidIO II IP Core User Guide Does Not Clarify How to Generate Testbench Correctly for Arria 10 Variations
Description
To generate a functional testbench for a RapidIO II IP core that targets an Arria 10 device, you must click Generate > Generate Testbench in the RapidIO II parameter editor. If you use a different method to try to generate the testbench, the parameter editor does not generate a working testbench.
Resolution
This issue has no workaround. To avoid this issue, use the recommended method to generate your Arria 10 RapidIO II IP core testbench.
This issue will be fixed in a future version of the RapidIO II MegaCore Function User Guide.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
