Knowledge Base Article
RapidIO II IP Core Might Declare Loss of Scrambler Synchronization If Link Partner Has Different Reference Clock Source
Description
If the RapidIO II IP core and its RapidIO link partner have
independent reference clock sources, the RapidIO II IP core declares
a scrambler synchronization error by setting bit [14] of the Port
0 Error Detect CSR at offset 0x340, around the time of the
first clock compensation sequence.
Resolution
This issue has no workaround.
This issue is fixed in version 13.1 Update 2 of the RapidIO II MegaCore function.
Updated 3 months ago
