Knowledge Base Article
RapidIO II IP Core Might Assert transport_rx_packet_dropped in Error
Description
The RapidIO II IP core should assert the transport_rx_packet_dropped output signal for a single Avalon clock cycle when the Transport layer drops a received packet. However, the IP core might assert this signal for longer than one Avalon clock cycle, when only a single packet is dropped.
Resolution
This issue has no workaround. Ensure you do not rely on the transport_rx_packet_dropped signal to count the number of Rx packets the IP core drops.
Updated 1 month ago
Version 2.0
