Knowledge Base Article
RapidIO II IP Core Hangs After Receiving MAINTENANCE Read Response With DONE Status but No Payload
Description
When the RapidIO II IP core receives a MAINTENANCE read
response with DONE status but without a payload, the
IP core should indicate an error. However, the IP core hangs.
Refer also to RapidIO II IP Core Does Not Return ERROR Response Packet to MAINTENANCE Request with Illegal Size.
Resolution
This issue has no workaround.
This issue is fixed in version 14.0 of the RapidIO II MegaCore function.
Updated 20 days ago
