Knowledge Base Article
RAM: 1-PORT IP Parameter Editor Is Missing a Legality Check for Invalid Options
Description
The IP Parameter Editor generates an invalid wrapper for the RAM: 1-PORT IP core
when you set the memory block type to Auto and the read-during-write
mode to New Data. The invalid wrapper allows you to set the
read_during_write_mode_port_a parameter to
NEW_DATA_WITH_NBE_READ even if it is an invalid option.
This issue affects the Quartus® Prime Standard Edition software and the Quartus Prime Pro Edition software.
Resolution
Set the read_during_write_mode_port_a parameter to
NEW_DATA_NO_NBE_READ inside the generated wrapper.
Updated 3 months ago
