Knowledge Base Article
Quartus Prime Pro Edition software erroneously applies location assignments and constraints to I/O pads instead of logical pin names
Description
In the Quartus® Prime Pro Edition software, the I/O pad atom does not replace the logical pin name. Instead, the I/O pad atom is inserted in between the logical pin name and the rest of the logic, and it has the suffix ~pad.
All assignments made to the logical pin name, including location constraints, are automatically applied to the pad. For example, the logical pin named clk has a corresponding pad called clk~pad. If you have a location assignment to clk, the assignment is applied to clk~pad instead of clk.
Resolution
There is no workaround. This issue will be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 2 months ago
Version 2.0
