Knowledge Base Article
Quartus II SignalTap II Logic Analyzer exits with an error when About Quartus II SignalTap II Logic Analyzer is opened from the Help menu
Description
If you run the stand-alone Quartus II SignalTap II Logic Analyzer, and then click About Quartus II SignalTap II Logic Analyzer on the Help menu, the Quartus II SignalTap II Logic Analyzer exits with an error similar to the following:
Internal Error: Sub-system: QUI, File: /quartus/sys/qui/qui_help_menu.cpp,
Line: 256
Cannot load library sys_mdb.dll: The specified module could not
be found.
Resolution
Do not click the About Quartus II SignalTap II Logic Analyzer command.
Updated 1 month ago
