Knowledge Base Article
Quartus II Compile Failure for VIP Clocked Video Output (CVO) Core due to Undeclared Variable
Description
The Quartus II software compiles failure for VIP CVO core due to undeclared variable.
Affected ConfigurationHappens only if Video in and out use the same clock option is enabled.
Design ImpactError (10207): Verilog HDL error at alt_vipitc111_IS2Vid.v(934):
can’t resolve reference to object “rst_vid_clk_reg”.
Customer cannot compile the core successfully in the Quartus II
software.
Resolution
- Open the source file, alt_vipitc111_IS2Vid.v file.
You can find this file under
QUARTUS_ROOTDIR/../ip/altera/clocked_video_ip/src_hdl. - Open the file, and go to line 934, or the line that contains
the following “
.aclr(rst_vid_clk_reg)” SDI configuration. - Edit this line by removing the “
_reg”, making the line as “/aclr(rst_vid_clk)” - Run and compile
This issue will be fixed in a future version of VIP MegaCore function.
Updated 2 months ago
