Knowledge Base Article
Quartus II Compilation Warnings for Nios II Stratix II 2S60 ROHS Example
Description
You might see the following warnings if you try to compile the Nios II Stratix® II 2S60 ROHS example design, installed at <Nios II EDS install path>/examples/vhdl/niosII_stratixII_2s60/standard or downloaded from the FPGA Wiki
Warning (10541): VHDL Signal Declaration warning at NiosII_stratixII_2s60_standard.vhd(59): used implicit default value for signal "cpu_data_master_read_data_valid_NiosII_stratixII_2s60_standard_clock_0_in" because signal was never assigned a value or an explicit default value. Use of implicit default value may introduce unintended design optimizations. Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(344): used initial value expression for variable "arg_length" because variable was never assigned a value
You can safely ignore these warnings.
The Nios II Stratix II 2S60 ROHS example is deprecated.
Resolution
None.
Updated 2 months ago
Version 2.0
