Knowledge Base Article
Qsys: if you edit an interface name, the name of the exported interface does not incorporate your edit
Description
If a Qsys component interface is exported by default, the name of the exported interface is based on the original instance name—the exported interface names are not renamed if you edit the instance name.
Resolution
To update the name of the exported interface (and the associated input and output signals of the system), click in the Export column and then rename the interface.
Updated 3 months ago
