Knowledge Base Article
qcrypt:<file name>.rbf:<number>: unexpected end-of-file
Description
You will see this error when using the Qcrypt tool to encrypt a compressed Raw Binary File (.rbf) which is not supported.
Resolution
To avoid this error, do not use compression for the .rbf that you want to encrypt.
Updated 1 month ago
