Knowledge Base Article
Problems Booting Linux on Golden System Reference Design
Description
Linux might be unable to boot from QSPI on the Golden System Reference Design. This can happen if the device tree blob (DTB) is larger than the maximum size assumed by U-Boot (8Kb).
Resolution
You can work around this issue one of the following ways:
- Update the U-Boot environment variable
fdtimagesizeas follows: - Alternatively, change the maximum DTB image size in the code.
Edit include/configs/socfpga_cyclone5.h. Find the line
specifying
fdtimagesize, and change it tofdtimagesize=0x3000\0.
1. At run time, start the U-Boot console.
2. Type the command env set fdtimagesize 0x3000 to
set the maximum DTB image size to 12 Kb.
3. Type the command saveenv to save this setting
for future boots.
Updated 3 months ago
