Knowledge Base Article
Pre-adder Square Mode Feature in Intel® Stratix® 10 DSP Implemented as an External ALM
Description
The DSP User Guides wrongly indicate that the pre-adder should be inside the DSP block in the following figures:
Figure 13. Pre-adder Square Mode (Intel FPGA Integer Arithmetic IP Cores User Guide)
Figure 36. Pre-adder Square Mode (Intel® Stratix® 10 Variable Precision DSP Blocks User Guide)
Resolution
However, Intel® Stratix® 10 DSP atom does not support pre-adder square mode.
You can still use this feature by using the Intel FPGA Multiply Adder IP, but the pre-adder square mode is implemented as an external ALM.
Updated 3 months ago
