Knowledge Base Article
Pause and PFC Frames Still Generated When Transmit Path is Re-Enabled
Description
The Low Latency Ethernet 10G MAC still services Pause and PFC frame requests after the transmit path is disabled and re-enabled. The requested Pause and PFC frames will be generated again when the transmit path is re-enabled.
This issue will be fixed in a future version of the Low Latency Ethernet 10G MAC.
Updated 2 months ago
Version 2.0
