Knowledge Base Article
Parameter "rstctrl_tx_lc_pll_rstb_select" of instance "stratixv_hssi_gen3_pcie_hip" has illegal value "ch4_10_sel" assigned to it. Possible parameter values are: "NOT_ACTIVE", "CH4_OUT", "CH4_10_OUT", "CH1_OUT", "CH7_OUT".
Description
This error can occur if the parameter force_hrc=1 is set in the Hard IP(HIP) for PCI Express® variant file. Typically this occurs if you are moving from a Gen 2 to Gen 3 variant and had to force the Gen 2 design to be an autonomous HIP or Configuration via Protocol(CvP) design. Gen 3 implementations only support the soft reset controller whereas the Gen 2 design can support the hard reset controller for autonomous HIP or CvP designs.
Resolution
Set force_hrc=0 and regenerate your variant using parameter editor.
Updated 2 months ago
Version 2.0
