Knowledge Base Article
Packet Loss in 8-bit Internal FIFO Buffer
Description
When you enable the SGMII on the MAC function with 8-bit internal FIFO buffer, the MAC function will not transmit the first packet into the FIFO buffer.
This issue affects MAC function designs with 8-bit internal FIFO buffer and SGMII PCS.
Resolution
No workaround.
This issue is fixed in version 11.0 of the Triple Speed Ethernet MegaCore function.
Updated 2 months ago
Version 2.0
