Knowledge Base Article
ODT Launches Off System Clock
Description
In designs with a separate address and command clock, the ODT output launches from the system clock, not from this address and command clock.
This issue affects the following configurations:
- DDR2 SDRAM controller (not DDR SDRAM)
- ODT is turned on
- CAS latency is set to three
- The design uses a separate address and command clock and not the default system clock
This issue has no design impact.
Resolution
Use a CAS latency of four, which means one extra cycle of read latency, or use the DDR2 SDRAM High-Performance controller, which uses the ALTMEMPHY megafunction to transfer all the address and command outputs to the correct clock.
This issue will not be fixed.
Updated 1 month ago
