Knowledge Base Article
Nios II SBT for Eclipse Unable to Create New Application and BSP from Template
Description
You should be able to create a new application and BSP from a template with the following steps:
- Select Nios II Application and BSP from Template.
- Choose your .sopcinfo file and select a template.
- Click Select an existing BSP project from your workspace.
- Click Create.
- Choose the desired BSP options.
- Click Finish.
However, if you try to create a new application and BSP with this method, the SBT creates a BSP, but no application, and the GUI becomes unresponsive.
Resolution
Perform the following steps:
- Click Cancel to close the previous GUI.
- Select Nios II Application and BSP from Template again.
- From the BSP list, select the BSP created previously.
- Click Finish.
Updated 24 days ago
