Knowledge Base Article
Nios® encryption only supports Verilog and VHDL. Error: Quartus® Prime® IEEE1735 Encryption was unsuccessful. 0 errors, 0 warnings
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 19.2 and earlier, you may see the error above when you encrypt a SystemVerilog file using the IEEE 1735 v1 Encryption Standard.
Resolution
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 19.3.
Updated 3 months ago
Version 2.0
