Knowledge Base Article
NativeLink Simulation of DDR2, DDR3, and LPDDR2 Interfaces Fails for ModelSim AE and ModelSim SE
Description
This problem affects DDR2, DDR3, and LPDDR2 products.
When you attempt to simulate a DDR2, DDR3, or LPDDR2 design
using NativeLink with ModelSim or ModelSim-Altera, NativeLink fails
and reports a parameter not found error.
Resolution
The workaround for this issue is to open the generated .do script
found in the ...simulation/modelsim directory in a
text editor, and change the following code:
vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L
altera_mf_ver -L altera_lnsim_ver -L arriav_ver -L arriav_hssi_ver
-L arriav_pcie_hip_ver -L rtl_work -L work -voptargs=" acc" dut_example_sim�
to the following code:
vsim -t 1ps -L rtl_work -L work -L altera_ver -L lpm_ver
-L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L arriav_ver
-L arriav_hssi_ver -L arriav_pcie_hip_ver -voptargs=" acc" dut_example_sim�
This issue will not be fixed.
Updated 3 months ago
