Knowledge Base Article
Must Enable Support for Nios II ModelSim Flow in GUI for DDR2 and DDR3 SDRAM Controller with UniPHY and RLDRAM II Controller with UniPHY
Description
If you intend to use your generated IP with the Run as Nios II ModelSim flow in Eclipse, you must turn on the Enable support for Nios II ModelSim flow in Eclipse option on the Diagnostics tab in the parameter editor, or else your design may fail in Eclipse.
Resolution
Ensure that you turn on the Enable support for Nios II ModelSim flow in Eclipse option on the Diagnostics tab in the parameter editor.
Updated 2 months ago
