Knowledge Base Article
Missing Nios II Perspective
Description
If you launch the Nios II SBT for Eclipse from a universal naming convention (UNC) path, the Nios II perspective does not appear in Eclipse.
This issue appears only on platforms running the Windows operating system.
Resolution
Do not use a UNC path to launch the Nios II SBT for Eclipse. For example, if the SBT for Eclipse is installed on a network drive, map the network path to a Windows drive letter.
Updated 3 months ago
Version 2.0
