Knowledge Base Article
Missing CRC In Pause Frame When 10GBaseR Register Mode is Enabled and CRC Insertion is Disabled in the Low Latency Ethernet 10G MAC IP Core
Description
When you enable 10GBASE-R register mode and disable TX CRC insertion through the configuration register, there is a possibility that the generated pause frame will contain no CRC.
Resolution
None. This issue will be fixed in a future release.
Updated 1 month ago
