Knowledge Base Article
MGL_INTERNAL_ERROR: Port object altpll_avalon|altpll inst sd1|phasecounterselect of width 3 is being assigned the port altpll_avalon|w_phasectrsel of width 4 which is illegal, as port widths don't match nor are multiples.
Description
Due to a problem in the Quartus® II software version 15.0 and earlier, you will get this error if an ALTPLL is generated in the Platform Designer with the Dynamic Phase Stepping feature enabled when targeting an Intel® MAX® 10 device.
Resolution
If using Dynamic Phase Stepping, implement the ALTPLL outside Platform Designer to avoid getting this error.
This problem has been fixed in the Quartus II software v14.0
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
