Knowledge Base Article
Megafunction <device> Hard IP for PCI Express v14.0.2 is not listed in any wizard.lst file in the specified library path(s).Wizard launch aborted
Description
This error message will be seen if attempting to open a v14.0.2 variation of the Arria® V, Cyclone® V, or Stratix® V PCI Express® Hard IP using the Parameter Editor.
The issue is due to the v14.0.2 variation not being recognized by the IP Catalog Editor.
Resolution
This problem can be worked around by editing the first line of the generated file to change from v14.0.2 to v14.0 description, for example, from:
VHDL variation
-- megafunction wizard: %Stratix V Hard IP for PCI Express v14.0.2%
to
-- megafunction wizard: %Stratix V Hard IP for PCI Express v14.0%
Verilog variation
// megafunction wizard: %Cyclone V Hard IP for PCI Express v14.0.2%
to
// megafunction wizard: %Cyclone V Hard IP for PCI Express v14.0%
Updated 1 month ago
Version 2.0
