Knowledge Base Article
MAC Function Does Not Assert ff_rx_dsav Signal when 64-byte Frame is Received
Description
This errata affects the Triple-Speed Ethernet MegaCore function.
When the rx_section_full register is set to 16, the MAC function does not assert the ff_rx_dsav signal for 64-byte frames.
This issue affects variants of MAC function with internal FIFO buffer.
Resolution
This issue has no workaround.This issue is fixed in version 12.0 of the Triple-Speed Ethernet MegaCore function.
Updated 1 month ago
