Knowledge Base Article
Low Latency 40-100GbE IP Core VHDL Model Cannot Simulate Correctly
Description
If you generate a VHDL model for a Low Latency 40-100GbE IP core, it cannot simulate correctly.
Resolution
This issue has no workaround. You must generate your IP core variation in Verilog HDL.
This issue will be fixed in a future version of the Low Latency 40- and 100-Gbps Ethernet MAC and PHY MegaCore function.
Updated 2 months ago
Version 2.0
