Knowledge Base Article
Low Latency 40-100GbE IP Core PTP Module Causes Arria 10 IP Core to Malfunction
Description
If your Low Latency 40-100GbE IP core variation targets an Arria 10 device, the PTP module causes the IP core to malfunction. This issue applies only to Low Latency 40-100GbE IP cores that target an Arria 10 device.
Resolution
To avoid this issue, you must generate your IP core variation that targets an Arria 10 device without a PTP module, by turning off Enable PTP in the Low Latency 40-100GbE parameter editor.
This issue is fixed in version 14.0 Arria 10 Edition of the Low Latency 40- and 100-Gbps Ethernet MAC and PHY IP core.
Updated 3 months ago
Version 2.0
