Knowledge Base Article
LL 40-100GbE IP Core Ignores FCS Errors in Flow Control Frames
Description
The Low Latency 40-100GbE IP core should discard received flow control frames that have an FCS error. Instead, the IP core ignores the FCS error and processes the flow control frame as if it had no FCS error.
Resolution
This issue has no workaround.
This issue will be fixed in a future version of the Low Latency 40- and 100-Gbps Ethernet MAC and PHY IP core.
Updated 3 months ago
