Knowledge Base Article
LL 40-100GbE IP Core Hardware Design Example Requires New SDC File
Description
The LL 40-100GbE IP core hardware design example fails timing. The issue is caused by clock name mismatches with the SDC file.
Resolution
To ensure the hardware design example can run correctly, you must replace the contents of the SDC file at <example_design_install_dir>/hardware_test_design/common/common_timing_a10.sdc with the following text:
derive_pll_clocks -create_base_clock derive_clock_uncertainty set_false_path -from [get_keepers {cpu_resetn}] set RX_CORE_CLK [get_clocks *|phy*|*rxp|*rx_pll*rx_core_clk*] set TX_CORE_CLK [get_clocks *|phy*|*txp|*tx_pll*tx_core_clk] set clk100 [get_clocks *|iopll*|clk100] set_clock_groups -asynchronous -group -group -group
This issue will be fixed in a future version of the Low Latency 40- and 100-Gbps Ethernet MAC and PHY IP core.
Updated 2 months ago
Version 2.0
