Knowledge Base Article
LINK_QUAL_PATTERN_SET in DisplayPort Receiver Supported at DPCD 1.1 Address
Description
When the GPU is not used, the DisplayPort IP core receiver supports LINK_QUAL_PATTERN_SET at DPCD 1.1 address (00102h) instead of DPCD 1.2 addresses (0010Bh - 0010Eh).
This issue may cause the physical layer (PHY) CTS testing to fail.
Resolution
To avoid this issue, set the LINK_QUAL_PATTERN_SET value using DPCD 00102h address or turn on Enable GPU control.
This issue is fixed in version 14.1 of the DisplayPort IP core.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
