Knowledge Base Article
libgcc_s.so.1 must be installed for pthread_cancel to work
Description
You may receive this error when you run the Quartus® II software on a version of the Linux operating system Altera® does not officially support. As a workaround, set the environment variable LD_ASSUME_KERNEL to the value 2.4 before running the Quartus II software.
Updated 1 month ago
Version 2.0
