Knowledge Base Article
JESD204B IP Core TX Soft PCS Outputs All Zero Parallel Data During Reset State
Description
When you select Enable Soft PCS for the PCS option parameter, the TX soft PCS outputs all zero during the reset state. Therefore, the deterministic latency for Subclass 1 mode is inconsistent.
This issue does not impact the functionality of the CDR at the receiver side because the data going into the CDR is not DC-balanced.
This issue affects the JESD204B IP core in Quartus II software version 14.0.
Resolution
None.
This issue will be fixed in a future version of the JESD204B IP core.
Updated 3 months ago
