Knowledge Base Article
JESD204B IP Core ed_synth Timing Failure (Arria V)
Description
The JESD204B IP core design example has a hold time violation to the transceiver.
This issue affects all versions that support the JESD204B IP core.
Resolution
You can use the set_min_delay command to change the absolute minimum delay for the path. The value to apply depends on the negative slack that you see.
For example, in a case where the negative slack = –0.04, apply a value of 0.1 ns (with around 0.06 ns as the guardband).
if {$::quartus(nameofexecutable) == "quartus_fit"} {
set_min_delay -to [get_keepers
{*inst_av_hssi_8g_tx_pcs|wys~BURIED_SYNC_DATA*}] 0.100ns
Updated 1 month ago
Version 2.0
