Knowledge Base Article
Java Heap Space Exception if Quartus II Compilation is Enabled
Description
If your design contains a C2H accelerator, and you select Build software, generate SOPC Builder system, and run Quartus II compilation in the C2H view, you might see the following error during Quartus II compilation:
Exception in thread "main" java.lang.OutOfMemoryError: Java heap space make: *** [c2h_hdl-t] Error 1
Resolution
Select the Build software and generate SOPC builder system option in the C2H Compiler settings window, and then manually launch the Quartus II software to compile the design.
Updated 1 month ago
Version 2.0
