Knowledge Base Article
Jabbers and OversizePkts Counters Issues
Description
This errata affects the Triple-Speed Ethernet MegaCore function.
You may observe both etherStatsJabbers and etherStatsOversizePkts increment when Jabbers are received. etherStatsOversizePkts should not increase when the Jabbers are received.
This issue affects variants of MAC function with statistic counters.
Resolution
This issue has no workaround.This issue is fixed in version 12.0 of the Triple-Speed Ethernet MegaCore function.
Updated 2 months ago
Version 2.0
