Knowledge Base Article
Is there any problem if a floating voltage exists on VCCH_GXB before it is ramped in Cyclone V devices?
Description
No, there is no problem if a floating voltage exists on VCCH_GXB before it is ramped in Cyclone® V devices. Leakage can occur between VCCH_GXB and VCC/VCCE_GXB which can cause VCCH_GXB to float to approximately 0.7V before the power supply is ramped up.
This is expected behavior and will neither cause any functional failure nor reliability concern to the device.
This can only be observed if VCC/VCCE_GXB is powered up before VCCH_GXB and the regulators were designed to leave the power supplies to float before they ramp up.Related Articles
- Is there any problem if a floating voltage exists on VCCE_GXB before it is ramped in Cyclone V devices?
- Is there any problem if a floating voltage exists on VCCH_GXB before it is ramped in Arria II, Arria V, Stratix IV, and Stratix V devices?
- Are there any problems if a floating voltage exists on the VCCH_GXB supply rail before it is ramped in Cyclone IV GX devices?
- Why is a floating voltage observed on the 2.5V VCCIO rail during power-up of Cyclone IV GX, Cyclone V, Arria V, Stratix IV or Stratix V devices?
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
