Knowledge Base Article
Is there any known problem with the Secure Device Manager (SDM) firmware in Intel Agilex® 7 FPGAs F-Series and I-Series with the density code of 019 or 023?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.3 and earlier, Intel Agilex® 7 FPGAs F-Series and I-Series with the density code 019 or 023 might not work correctly.
The Secure Device Manager (SDM) interacts with multiple sub-system managers (SSMs) like Local Sector Managers (LSMs).
Those SSMs have their RAM with the repair fuse. However, the SDM firmware may incorrectly apply the repair fuse information to the SSMs. Because the RAM repair is random, it is hard to estimate what failure symptom will be observed. Intel strongly recommends applying the following resolution to fix this problem.
Resolution
To fix this problem, download and install the latest device firmware patch according to your Intel® Quartus® Prime Pro Edition Software version.
- Intel® Quartus® Prime Pro Edition Software version 22.1 - Patch 0.40fw or newer
- Intel® Quartus® Prime Pro Edition Software version 22.2 - Patch 0.39fw or newer
- Intel® Quartus® Prime Pro Edition Software version 22.3 - Patch 0.27fw or newer
You can find the latest device firmware patch for each Intel® Quartus® Prime Pro Edition Software version from the following Knowledge Database article.
What is the latest device firmware for Intel Agilex® 7 and Intel® Stratix®10 devices?
This problem has been fixed since Intel® Quartus® Prime Pro Edition Software version 22.4.
