Knowledge Base Article
Is there any known issue when using altdq_dqs megafunction as RLDRAMII mode in Quartus II 11.1SP2?
Description
Yes. When you use altdq_dqs megafunction and set “RLDRAMII mode” as “x18” or “x36” in Parameter Settings page, you may find the port width of dqs_bus_out in the IP top file is mismatched.
Declaration of dqs_bus_out in IP top file is
output   [0:0]  dqs_bus_out;
The expected declaration of dqs_bus_out should be:
output   [1:0]  dqs_bus_out;
As a workaround, please change the port width of dqs_bus_out manually. This issue will be fixed in  Quartus® II software future version.
Resolution
Change
To
Updated 2 months ago
Version 2.0
