Knowledge Base Article
Is there an issue with Configuration via Protocol (CvP) when configuring using CvP with truncated or corrupted periphery/core bitstream in Intel Agilex™ 7 FPGA devices?
Description
In the Quartus® Prime Pro Edition Software version 21.2 and below, performing CvP configuration can cause the Agilex™ 7 FPGA devices to hang if a truncated or corrupted periphery/core bitstream is sent. Once the FPGA hangs due to receiving a truncated or corrupted periphery/core bitstream, subsequent reconfiguration via CvP Initialization Mode/CvP Update mode cannot be performed.
Resolution
This problem is already fixed in Quartus® Prime Pro Edition Software version 22.2.
Updated 1 month ago
