Knowledge Base Article
Is there an issue with Bus LVDS (BLVDS) in Arria II GX, Arria II GZ, Arria V, and Stratix V devices?
Description
BLVDS will not work correctly in the Arria® II GX, Arria II GZ, Arria V, and Stratix® V device families if the BLVDS I/O standard is selected in the Quartus® II software. The negative leg will fail to toggle and could remain tri-stated or drive high.
Resolution
For pins that you intend to use as BLVDS, use the 2.5V Differential SSTL I/O standard in the Quartus II software for the Arria II GX, Arria II GZ, Arria V, and Stratix® V device families . The BLVDS I/O standard is removed in12.0 or later versions of the Quartus II software for projects that use these device families.
For further information on using BLVDS in Altera® devices, refer to AN522: Implementing Bus LVDS Interface In Supported Altera Device Families (PDF).
Updated 2 months ago
