Knowledge Base Article
Is there a syntax error when using the VHDL file of the ALTMULT_COMPLEX FPGA IP?
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 22.1 and earlier, the VHDL file generated for the ALTMULT_COMPLEX FPGA IP, <ip_variation_name>.vhd, contains syntax errors.
Using the generated IP files in the VHDL language is impossible.
Resolution
As a workaround, the user should generate the IP in Verilog HDL language.
Updated 3 months ago
Version 2.0
