Knowledge Base Article
Is there a problem when simulation ALTDQ_DQS2 megafunctions generate by the Quartus II version 12.0?
Description
Yes, there is a problem when simulation ALTDQ_DQS2 megafunctions generate by the Quartus II version 12.0.
When ALTDQ_DQS2 in output-only mode, Full-Rate, with no dynamic config or output phase alignment blocks, the core left
the output strobe enable dangling.
Resolution
Add the following code : assign fr_os_oe = 1\'b0;
to ALTDQ_DQS2 megafunctions source file as a workaround.
Updated 2 months ago
Version 2.0
